- 11 Jan 2006
Hi Guys i recently tried to install some new Ram into my Mobo & didn't seat one of the sticks properly & when i tried booting it up it started for a few seconds then it auto shut down so i noticed my error & seated the 2nd stick properly & tried again this time it booted upto the NVRAM checking > Ok part then failed again i did this several times & tried 1 stick etc swapped them etc but i think they are incompatible so for some unknown reason i thought it would be a good idea to remove the Cmos Battery & put the old ram back in and reboot which i did & it rebooted fine > Except now all my USB ports don't work ??
I suppose what i'm getting at is have i shagged the Mobo or do i need to do something to get the USB's working again i went into the Bios settings and both USB 1.1 & 2.0 are enabled so i would have thought they would just work?
Please help
AMD 939 3800+ X2
Mobo - A8N-VM
Please help
AMD 939 3800+ X2
Mobo - A8N-VM
