- 17 Feb 2006
I am experiencing games crashing all the time. I have recently upgraded to a new Lian Li V1000+ case which I thought had fixed the problem with better cooling, but it started again today.
A while back my motherboard lost all its settings and I have chosen AUTO for most of the setup but would like someone to confirm the setup is correct and not causing any problems.
I am currently running:
DFI Lanparty Ultra B
Barton XP 3200 512L2 Cache
OCZ 2x512MB 3200 Platinum
ATI AGP 800XT PE
Raptor HDD
My Gcard temp in games is around 50-52.5
My memory in games is 40-44
Everything else is pretty cool.
Here are my motherboard settings:
Advanced Chipset
System performance: Optimal
greyed out
CPU interface: Optimal
Memory timings: Optimal
T(RAS): 6
T(RCD-Read): 3
t(RCD-Write): 3
T(RP): 3
CAS Latency: 2.0
T(RC): 13
T(RFC): 15
Genie BIOS Settings
Current CPU frequency is: 2200Mhz
CPU Clock Spread Spectrum: Disabled.
CPU Clock Settings: 200Mhz
AGP Clock Setting: Auto
CPU Ratio: X 11
DDR DRAM Clock: By SPD
Current DDR Frequency is: 200Mhz
Current CPU Voltage is 1.63 V
Current DIMM Voltage is: 2.59 V
If anyone can help I really would appreciate it. Should I manually set the DIMM timings and should I change the voltage?
Also posted in cooling and motherboards, sorry if this is a duplicate.
ATI AGP 800XT PE
Raptor HDD
Advanced Chipset
greyed out
T(RAS): 6
T(RCD-Read): 3
t(RCD-Write): 3
T(RP): 3
CAS Latency: 2.0
T(RC): 13
T(RFC): 15
Genie BIOS Settings
CPU Ratio: X 11
