Help requested for Microsoft Office problem
14 Apr 2009
Bedford , United Kingdom
Hi,
In a nutshell, I have a Microsoft Office document, the front page is a header, footer and a graphic on the side.
I want all subsequent new pages to be blank, however when I hit return at the end of the document, or choose "insert blank page", it repeats a copy of the first letterheaded page instead of a completely blank page.
I had somebody do some finalising on the document to lock the front page elements in place so they couldn't be moved or edited, which may be the problem.
Any ideas what could be done to fix it would be greatly appreciated !
2 Nov 2013
I think you've probably got a master slide set up with all that stuff in place. Go to view and master slide, and that's where you can edit these things. I think you can create a set of sub-pages to the master (and make one of them blank) and then for each new page you can choose which of the masters to base it on.
22 Jan 2014
Or just use the cover page function?
Or why use headers and footers anyway if it's only for one page? Just put the text you want where you want it e.g. using borderless text boxes
