1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Home Server - Minimal power
Discussion in 'General Hardware' started by gtir666, 27 May 2010.
  1. Big.Wayne
    Capodecina
    Let us be the judge of that! :p
    OcUK don't stock the Sempron 140! :( . . . I asked them but there probably isn't enough profit in selling them! :D
  2. Gamer4Life
    My Home Server - Minimal power solution
    Approximate power consumption...
    HP hdx18t-1100 cto laptop, 30w, 14.4v, 5069mAH.
    External HD's, 7w, 12v, 2A (x2) = 14w, 24v, 4A
    Total approximate power consumption, 37w, 38v, 4.5mAH
    [​IMG]
  3. AtaRo
    Wise Guy
    ASRock N68C-S UCC £30.95 inc. VAT
    [​IMG]
    AMD Sempron 140 £26.50 inc. VAT
    [​IMG]
    and some of those green drives
  4. gtir666
    Gangster
    Man those Sempron cpu's are cheap as chips (excuse the pun:rolleyes:)
    WHS is the os i had in mind it. Was going to try it but says you cant activate the trial and have to start over:confused:
  5. Speed
    Sgarrista
    Yeah they work really well as low energy server chips, I have a 140 in mine and it works great. Got it with a motherboard for £40 2nd Hand, but at current new prices you might as well go that way for the warranty.
  6. wonko
    Wise Guy
    I've got WHS running on an AMD 4850e quite happily here if that helps.
    IIRC, if you install the trial version then you have to do a 'server reinstall' as the trial period ends which isn't too painful (essentially redefining users and share permissions plus installing add-ins).
    Oh, and if you're thinking about the current version of WHS (i.e. not the WHS2 Vail trial) then watch out for Advanced Format drives like the WD green EARS models - they need a bit of special treatment.
  7. trentlad
    Mobster
    You should see this guy for an extreme power saving NAS!
    He transformed his 1st Gen eeePC into a NAS FTP. Using Dynamic DNS for sharing remote access and [email protected] to remote desktop the netbook. To get a little more performance from the netbook, he used eeeCtl to overclock the atom [email protected] MHz (he shows a 720p movie running on this thing).
    I don't think I've seen a lower power NAS than this one.
  8. Speed
    Sgarrista
    The model he used doesn't have an Atom CPU, it is a Intel Celeron M 900MHz underclocked to 630MHz. But yes would be pretty low energy, main issue would be connecting multiple hard drives to it.
  9. JonJ678
    Capodecina
    The first gen eeepc was an absolute con. Advertised everywhere as a 900MHz celeron, then turned out Asus dropped the ball on the cooling system and set them all to 630MHz. I was livid when I found out (shortly after buying one).
    I'm finding the most difficult part to specifying a home server to be working out how much processing capacity I need. Maybe a dual core atom would be enough, but maybe not. The custom pc crowd says it wont be, yet oem's are using them for raid 5 NAS systems. Really hard to tell if the atom is enough, or whether an amd/intel dual core is a better plan.
  10. Speed
    Sgarrista
    Depends what you are using it for, I ran a home download and storage server on a Atom 330 board (D945GCLF2) with 2GB of DDR2 and it ran fine. I had no problems at all using Windows Vista / Windows 7 64Bit.
    The only reason I moved over to a full ATX board and Sempron 140 was the need for more SATA ports and room for future expansion. It was also cheaper than going for one of the ION based boards.
  11. JonJ678
    Capodecina
    Ah, but therein lies the problem. The longer one thinks about useful things for a 24/7 machine to run, the more tasks one comes up with. Balancing hardware performance against what you want it to run is tricky. For example,
    Raid 5
    Disk encryption
    Ipsec
    Firewalling
    Snort
    Rtorrent
    Tor
    Squid
    Local aptitude repo (can't remember the name)
    Media serving (hd?)
    Rsync
    User-mode linux
    Email server
    FTP server
    Can't think of any more at present, but I'm sure the list is longer than this. Each one comes with an overhead, and working out which ones you're willing to pay more for vs cost of hardware is tricky.
  12. Big.Wayne
    Capodecina
    Lots of nice idea's :)
    I'm not one to "label" a computer with a specific tag such as HTPC or WHS etc but think the labels work ok to describe the required function . . .
    Any reason one cannot combine all these functions into a single low powered build?
    • Home-Server
    • Download Box
    • HTPC (PVR etc)
    • NAS
    • Virtual Server
    I'm sure there are some good reasons but they didn't become apparent to me yet! :o
  13. JonJ678
    Capodecina
    Finding a power supply is the main issue I think Wayne, Pico psu's start to look like a bad plan when there's little to no airflow and you want to run multiple hard drives. Virtual server has the potential to require phenomenal computing power too depending on how you define it.
    Or at least, choosing a power supply is proving difficult for me without going for a full size atx one. Pico's are only good for 65% their rated wattage when operating 24/7, and further derate if they get warm.
    I'm trying hard to combine such things in one (small) box, but not managed to work out how yet :)
  14. Cycrow
    Mobster
    alot of server tasks really dont need much power for just home use really
    quite often, its the os itself that needs the bulk of the processing power.
    im currently running a few servers for different things. One of them is a web/ftp and mail server.
    it hosts a few websites, and several email domains, web mail, various spam filters and virus checkers, etc and a few other things. And it runs perfectly fine using a Via EN1200, which is a passive 1200mhz cpu. And 100w PSU in a 1u rackmount, althou it usually only runs at about 20w, althou not tested it in awhile
    very rarely do i see the cpu above about 30% usage.
    althou its running FreeBSD without a gui, and is mainly accessed via SSH
  15. agent_paul
    Gangster
    I'd like to know what PSU people would recommend. If this machine was to be on most of the time and serving files, what PSU would you be using?
    Im guessing that storage space would also be a issue. does a machine with more than 3/4 hard drives be about right? Would a pico psu still be alright for that? (assuming the mobo is one of those low power atom/via boards)
  16. Caracus2k
    i ran the asus ion/atom board with intergrated Nvidia graphics and the dual core 330 chip for a while in a Silverstone SG06 case (comes with a good 300w psu).... was a good little computer and very low on power usage but eventually decided that i wanted something a bit snappier and changed it for an I3. A 330 Ion/Atom build should be ok for home server. Dual core processor that clocks up to 2ghz withouy issue although is very slow on a clock for clock basis with more conventinal chips/ +1 for Samsung F3 drives btw
  17. gurusan
    Capodecina
    I'll be trying out Vail on an Atom 230 with 1GB ddr2 in a few days....if it's too slow I'll just install linux or freenas
