1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How can I get SPDIF or TOSLINK digital sound from an older Macbook?
Discussion in 'Apple Hardware' started by MikeHunt79, 8 Jun 2010.
  1. MikeHunt79
    Capodecina
    I've recently bought one of the older Macbooks which only has analogue out for the sound.
    No digital, which is a bit of a pain as I was hoping to hook it up to a DAC.
    Is there anyway of getting digital sound out? I was thinking about buying some sort of USB soundcard, but I guess it wouuld have to be compatible with OSX.
    Are there any that exist or will I have to start saving for a macbook pro?
  2. Spyhop
    Which MacBook is that, a 32bit Core Duo one? I thought they all had combined headphone/optical out.
  3. MichaelHo
    Wise Guy
    The headphone socket is a optical out too, you will need a 3.5mm jack to toslink cable (cheap on the bay). I use this to connect the macbook to my AV amp and it runs surround sound perfectly.
    This is with the original CoreDuo Macbook.
