1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to tell if brake disks need replacing?
Discussion in 'Motors' started by Over Clocker, 19 Apr 2010.
  1. Over Clocker
    Man of Honour
    Hi guys,
    Over the past week by front brakes (BMW E46 330i) have started to squeal a bit. I've checked the pads and there is loads let on them, as they were replaced about 4 months ago or so. How could you tell if the disks are worn down, and would this cause squealing?
    It does sound like a more metal on metal sound rather than just dust, and there was some scoring on one of the disks.
    Cheers,
    Mal
  2. Janesy B
    Caporegime
    The squeaking will be the pad, not the disc and some copper slip on the back of the pad should sort that out. You should replace the disk if it has a large lip, corrosion or scoring.
  3. jamoor
    Sgarrista
    try taking it to a garage.
  4. NightShadow
    Wise Guy
    Have you check bot sides of the discs? Discs which look fine on one side can be completely FUBAR on the other as I found on my rear discs.
  5. Clarkey
    Capodecina
    You checked both the inner and outer pads? On the 320d the inner pads wore out completely but the outer ones still looked fine.
  6. Sounds more like you have a small stone stuck in there.
  7. dannyjo22
    Caporegime
    Haha hopefully next time you post a thread for help or advice everyone will just post the same back to you or take it to a pc repair shop ;)
  8. smr
    Sgarrista
    don't mean to sabotage thread but i just got 2 new front tyyres fitted at ats and was told my front discs are wearing thin... got quoted 140 quid for them... this a good deal?
  9. mike66uk
    Gangster
    I had this problem. Squealing noise coming from one wheels. Took the pads off and turns out there was a small bit of grit stuck between the pad and the disc, a quick sand down of the pad and clean up, put it back in and problem solved.
  10. jamoor
    Sgarrista
    TBH with something like brakes, it's probbably best to get a professionals opinion on the matter.
  11. Gaijin
    Don
    They are noisy, it's not like they aren't working.
    Squealing is usually due to lack of lubed shims, aggressive pads, lack of pads :D or pad movement in the caliper.
    Lube the shims first before you do anything more drastic.
  12. Lopéz
    Man of Honour
  13. Janesy B
    Caporegime
    Brakes are about the easiest thing to do on any modern car.
  14. The Edge
    I'd say that's about right.
  15. Gaygle
    Capodecina
    Yeah that's great! I think Bugatti charge roughly 10 times that for just ONE disc.
  16. Jamous
    Wise Guy
    Post up some pics and we'll give opinions
  17. St0rmer66
    Mobster
    As an indication.. 2 front discs on my motorbike are over £300! :eek: .
  18. Scania
    Capodecina
    I had an old Astra Belmont that was actually worse than that - when the garage took the wheel off, what little was left of the disc fell away! :o:o:o
  19. Liampope
    Mobster
    :eek::eek:
    On second thoughts - naaaaah - there's plenty of life left in that! All they need to do is unstick the probably seized inner piston, and seize up the outer with some fine grit or something. Then they can do the same miles again on the other side of that disk. Simples :)
  20. Booner!
    Sgarrista
    I'm looking at £600 for just discs alone :D
