Hi
I have a website where the root of the site (example.com) gets redirected to a sub directory (example.com/v2). This is the code i am using:
However, i how have some subdomains i wish to use. The files for these are located in http://example.com/subdomains/domain1. And cpanel is setup so you access domain1.example.com. However, if i go to domain1.example.com it is still forwarding me to example.com/v2. if i go to domain1.example.com/index.html it works correctly and displays the html file of the subdomain. Also if i remove the redirectMatch rule domain1.example.com works correctly.
Can anyone suggest what i need to do to get this working?
Thanks
Code:
RedirectMatch ^/$ http://example.com/v2/
Thanks
