Html body tag modification?
25 Oct 2004
Sunny Torbaydos
Hiya,
Working on a CMS type site at the moment and one of the JS scripts i want to use requires that the <body> element have an onload function for it to function.
Thing is i cannot add the onload function to it as the <body> element is created by the CMS itself, I only have control of the content between the <body></body> elements.
Is it possible to alter the <body> element through js to add the onload part ?
OP
25 Oct 2004
Sunny Torbaydos
Actually run into another problem with javascript.
Using a chained drill down menu script i need to initiate them using
Code:
initListGroup('category_list', document.csv_genfrm.["csvdata[type]"], document.csv_genfrm.["csvdata[compression]"]);
But because of how my form data is stored (php/sql session) and how i process the data using a foreach loop javascript doesnt like the [] around my form input names.
Is there anyway to get around this, i've tried the usual " etc around the data but it wont work.
