My Fiat Stilos done 60k now and the only thing that has gone wrong is 1 bulb. The car computer told me which bulb it was when it failed. But Fiat being stupid decided to place the light behind the washer fluid bottle so that had to be removed and also a few thick cable pipes. But after about 1.5 hours and very scrapped skin its fixed!
Alot of newer cars are being designed like this. Audi's for one, I've heard some of the new Citroens are just as bad. Soon be a dealer job to change a bulb Fog
Yes, but then I can change my Mondeo bulbs in seconds too, and the lights do not fall off like your Jap build quality MR2
Please please tell me you have a 2.5V6! One of mine has gone in my mk2 and I want to replace them both with some Philips, but according to my Haynes I need to remove the grill and whole headlight to do this!?
One of the best i've heard is the new Renault Megane, friend down the road had a headlight bulb blow, you have to jack the car up, remove the front road wheel then reach up into the arch and feel around for the bulb. What a joke!
Helped change a sidelight bulb on a 156, had to drop the undertray and get at it from underneath, **** poor design
it can be done without removing the headlight but is much easier to do with the headlight out it's only a few screws
Sounds like some of you should be taking halfords up on their "We'll fit it" offer just to see them try it
