So, 2 weeks ago I came home to find several ring mains off. It had been really REALLY stormy while we were out - but I didn't connect the two. I investigated and basically we have a secondary consumer unit feeding the upper half of the house - its RCD had tripped taking that entire section out.
It happened again during rainy weather and I started suspecting it was a leak into the loft, affecting lighting rings. Long story short - the cause is two exterior lights on a roof terrace in my landlord's room. His builders mounted the light switch upside down so I didn't identify it when testing the first time
Recently (past month) the walls bearing these lights and cables have been modified (neighbour removing shared chimney stacks and adding air bricks).
So - given the fault is directly affected by rain (only trips literally while it's being rained on heavily) - and it's only a short stretch from the doorway, along to one fitting and then the next... How do I identify which bit is causing leakage to ground?
I'm guessing this isn't something a normal multimeter can do. I'm an electronic engineer and would rather not raise the dispute with neighbour so, if I can identify it myself I'll happily sort it.
Suggestions?
Suggestions?
