£20, Must be sold from Asda if it mixes well with something make sure it's coke as I have lots of coke.
There's a new Baileys out with something or other in it, limited edition I think that I want to try. I am not gay. /Indian guy from Bad Santa
Jack Daniels I had a cocktail last weekend that consisted of Jack Daniels, Amaretto (sp?) and Pepsi in a tall glass with ice. It was awesome. I suggest you give it a whirl with the coke instead It's a really tasty long drink EDIT: It was on the 7 deadly Sins list at Slain Castle bar. It's called "Wrath"
Southern Cmf, or Vodka, make sure its good like absolute or smernof blue etc ok goods the wrong word, "not bad" would be better
Wont get much for £20 but id just get pack of lager and bottle of Dooleys or Baileys to chase, or perhaps some Scrumpy aswell for snakebites. Most spirits are over 12 quid a bottle though so only leaves enough for 1 bottle and a few cans
It depends on what you want, I find jim beam white a little bit sweet sometimes, although I do like it, I prefer JD then i prefer jim beam black over JD. My preference of whiskey/bourbon/sourmash goes as follows. soco < Jim white < bullet < JD < Jim black < Makers Mark < JD single barrel. But JD single barrel is > * Unless you want to get onto scotch. KaHn
Sounds pretty good actually. I used to mix Amaretto with Coke quite a lot, it comes out tasting like Dr Pepper.. but gets you drunk too.
