I'm stuck, what card do i buy? £200-300
AMG
AMG
18 Aug 2008
lincs, spalding
Some of what you posted does not make sense, but to answer your question I would still go with a GTX470 atm as it does overclock quite well.
if you overclock a HD5850 to the same speeds as the HD5870, the HD5850 will hold its own and very well against it, however in some situation it may be 10% slower than a HD5870 some people have tried.
the GTX470 does overclock well, but not as well as the HD5850 thats the point, okay fair enough it has less cores which does make a difference compared with its bigger brother, but for £200 thats just uncanny. It will be interesting to see a bechi with a GTX470 overclocked to its max and a HD5870 I got a feeling the HD5870 still maybe faster.
for the moment as you can tell I ve got two older gen Radeons which I am not upgrading, as I see little point in it.
Personally I m waiting for the smallier fermis to pop out and play unless they take up too much power, I only want it for linux
18 Oct 2007
Yeah I understand all this, still the part I highlighted doesn't make sense. :p
I would say the GTX470 would probably come out ahead, they seem to scale better and from the guru3d results it's almost on par with the GTX480 when overclocked, however you would probably need to run both at silly fanspeeds to maintain these speeds so it doesnt really matter.
