Hi all, Im in need of a new PSU. I've currently got an Enermax infiniti 650w, but its on its way out now. My current specs are: Intel C2D E8400 Asus Maximus Formula Powercolor 4870hd 1 Sata drive, 1 IDE drive I was told i might be able to use a lower wattage and have everything work fine overclocked ? Around 550w or so ? Is this the case ? Thanks.
id go with corsair personally http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS&groupid=701&catid=123&subcat=1084 not sure what wattage is right or you, but id go with this seeing as you were fine with 650W before, and this on one week only
http://www.overclockers.co.uk/showproduct.php?prodid=CA-026-BQ&groupid=701&catid=123&subcat=1083 How much are you planning on spending?
In that case i would seriously recommend this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-026-BQ&groupid=701&catid=123&subcat=1083
If you want to save money and modular isn't imperative then go for this, its easily powerful enough: http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OC&groupid=701&catid=123&subcat=1098
Will this do ok ? Does the lower power rating matter ? http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-CS&groupid=701&catid=123&subcat=
