1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Is my DVD Drive Dead???..
Discussion in 'Optical Storage & Writing' started by Simian, 6 Jun 2006.
  1. Simian
    Sgarrista
    I've got a LiteOn SHW-1633 which was pre-installed in my Advent PC which has now decided that any DVD I put into the drive is a 'Blank CD' or the Icon just changed to DVD-ROM and nowt happens!...
    PowerDVD/WMP/WMP Classic... None of em recognise that there is a DVD in the drive!?!. :confused:
    Its an AMD 3400+, 512Mb Ram, WinXP Home System (SP2), with PowerDVD, WMP 11, WMP Classic (K-Lite Mega), LiteOn RPC 1 Firmware, Nero 7 Premium.
    Do you recon the DVD has just given up the ghost!?!... It Records Discs fine (Well CD's.. Not tried a DVD for ages) or is there summut else that might be causing it?.. I've checked for Star(thinngy) again, which I had about 3 months ago and got rid of!
    Should I bite the bullet just part with £35 and get summut else!?!... What Drive do you guys currently recommend??..
    Cheers
    Sim :(
  2. MikeTimbers
    My Liteon did exactly the same thing. I'm buying a new drive - anything but Liteon - soon, probably an NEC.
  3. Simian
    Sgarrista
    It only seems to aknowlege a DVD in the drive if I re-boot with the disc in the drive... then it works no probs! :confused: :mad:
  4. roddypoddy
    Wise Guy
    My lite-on(also in an Advent) expired about 6 months ago,a mate gave me a philips which is fine, my dvd-rom is shot now,so i,m looking at putting in another writer,any recommendations,am looking at the NEC,s,would like to order tonight,thanks all.
