19 Feb 2010 at 11:15 #1 tundra tundra Associate Joined 29 Dec 2008 Posts 119 Do not post images that contain competitors! i find the volts a bit odd but i don't know if this is ok my spec is: gigabyte p35 q6600 4gb 150gb raptor, 500gb + 640gb hdd 4870 asus xonar 600w ocz stealthxstream thanks ahead Last edited: 19 Feb 2010
19 Feb 2010 at 11:19 #2 RJC RJC Don Joined 29 May 2005 Posts 29,009 Location Kent Don't bother using software to check volts, only use a multi meter. My system reads the same.
19 Feb 2010 at 13:56 #3 tundra tundra Associate OP Joined 29 Dec 2008 Posts 119 RJC said: Don't bother using software to check volts, only use a multi meter. My system reads the same. Click to expand... thanks, i just went into bios and it seems fine
