ive forgoten how pcs fit together :p
18 Mar 2009
hi guys. its been ages since ive messed around with my pc. so long ive forgoten what motherboard i have and all the technical stuff. anyway i think i need to replace my CPU. i have a phenom II 720 black edition (2.8x3). is this a decent CPU still? how do i know what other CPU's my motherboard will take? thanks
26 Oct 2010
Leatherhead
If it's AM3 it should take any modern AMD CPU with a BIOS update. There's not a lot wrong with your current processor though, so it might be worth sitting tight till you are ready to do a full upgrade. Maybe spend the money on a graphics update instead?
OP
18 Mar 2009
ok cool. i was spured on to do an upgrade by the fact i cant play the new combat missions game. but it turns out the game is broken, not my PC. my graphics card isnt great (4790 1gb i think, not 100% sure) and is slowly artifacting to death, so i might as well hang on to it untill it dies :D. thanks guys, i appreciate it.
