Just got a 9800 pro (for my little brothers pc), how to see temps?
OP
6 Nov 2004
Lol lucky you, I spose if you buy a zalman and get similar volts to a 9800 pro (might need to check on that), theres nothing stopping you at all.
28 Jul 2003
Dundee
LoopyLee said:
I got a 9550 Radeon with R360 GPU, does tis mean I could clock this card as high as a 9800pro?
No fan on card bit basic with that but I have read the R360 is best and my card is fitted with one
Any tips?
i'd presume the 9550 is a 4 pipe card? and i dont have a clue whether it'll have the same memory bandwidth (256mbit) as the 9800pro or if it can be unlocked (doubtful as i havent heard anything from overclockers about it)
Caporegime
26 Aug 2003
Leafy Cheshire
Yeah its definately NOT an r360 core, rv350 or rv360 are the two choices.
Should get quite a bit of speed out of an rv360 core (possibly needing a pencil voltmod), seem to remember getting a LOT of speed out of my 9600XT (temporary card when I blew up my 9800PRO @ XT).
OP
6 Nov 2004
paradigm said:
You won't overclock it because you cant see temps :confused: Thats just bizarre.
lol.. Now i'm scared to overclock again :D, i'll just overclock it a little that way I know im not pushing it.
Caporegime
26 Aug 2003
Leafy Cheshire
Don't worry I was REALLY pushing mine, it was vmem, vcore and vtt modded, it had one mother of a socket A cooler on it, as well as ramsinks. Besides, it was my vapochill dripping condensation onto the AGP slot that killed it :(
