1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
just orded 2 new gpu and psu will i have anough power
Discussion in 'Graphics Cards' started by woody79, 28 May 2013.
  1. woody79
    Gangster
    will this psu be anough for 2 power my crossfire setup
    2xVTX3D HD 7870 tahiti Black Boost Edition 2048MB
    seasonic
    Model Number:M12II-850BRONZE
    Package Type:Retail
    Warranty: 5 Years
    Type:ATX 12V
    Continuous Power:850W
    Connectors:
    1 x 20/24 Pin Main Power
    1 x 4+4 pin Main Power
    1 x 8 pin Main Power
    4 x 6+2 pin PCI Express Connector
    8 x 5-pin S-ATA Connector
    5 x 4-pin peripheral
    2 x Floppy Power
    PFC (Power Factor Correction):Active
    AC Input:100V to 240V
    Over Voltage Protection:Yes
    Under Voltage Protection:Yes
    Short Circuit Protection:Yes
    Over Power Protection:Yes
    Over Current Protection:Yes
    Over Temperature Protection:Yes
    Colour:Black
    Cable Type:Semi Modular
    Cable Sleeving:Black Web Full Sleeve
    Cooling System:1 x 120mm Fan
    Product Width:150mm
    Product Height:86mm
    Product Depth:160mm
    Gross Weight:3.12Kg
    Special Features:
    High Reliable Japanese Brand Capacitors
    Ample +12V Outputs
    Active Power Factor Correction [99% PF Typical]
    Smart and Silent Fan Control [S2FC]
    12cm Ball Bearing Cooling Fan
    Soft-Mount Rubber Cushions
    Multi-GPU Technologies Supported
    Package Contents:
    Power Supply Units
    UK Power Lead
    Modular Leads
    Cable Set Bag
  2. RJC
    Don
    More than ample :)
  3. Gregster
    Caporegime
    +1
  4. whyscotty
    Sgarrista
    And then some
  5. LtMatt
    Caporegime
    And then a little bit more
  6. woody79
    Gangster
    excellent cant wait to see what they can do picked them up cheap should be a good boost over my 580 gtx
  7. Drangueos
    Mobster
    with 850W you can use 3 or 4 HD 7850 :p and I'm not joking
  8. Phixsator
    Mobster
    Im running 2 7950 with a mild OC to 925 together with a gt 640, 3 HDDs, 1 SSD and a OCed powerhungry 8350 on a XFX Proseries XXX 850w and it doesnt give a f..k :) you be more than fine
  9. Something Else
    Mobster
    Could run 2 7970's off that ;)
  10. pastymuncher
    Man of Honour
    If you have a Gigabyte motherboard make sure you flash to the latest bios before using the 7870 LE's. They tend to not work with older mobo bios.
  11. MOOGLEYS
    Capodecina
    That PSU has 70A available on the 12v rail. You will be more than fine.
