1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Layout help/critique
Discussion in 'HTML, Graphics & Programming' started by Mr Joshua, 18 May 2006.
  1. Mr Joshua
    Mobster
    I've been tinkering with my site and trying to make it look a little more interesting, here are the results:-
    Screenshot 1
    Screenshot 2
    Screenshot 3
    As you can probably see the only difference between them is the navigation buttons at the top.
    Which do you think fits better with the overall page?
  2. Augmented
    I found #2 the most balanced and readable :).
  3. Mr_L
    Mobster
    #2, but if you're going to have fixed width keep it under 800px wide. :)
  4. Stellios
    Capodecina
    Number 2 is the nicest by far.
    As said, keep it to 800 pixels wide ad you should be fine.
  5. Mr Joshua
    Mobster
    Cheers for the replies, number 2 it is!
