Just ordered one of there based entirely on your brilliant review! Thanks for uploading the pictures as well
i might consider buying this also when i come back from holiday
is there any ghosting ingames with the 5ms response? and can u post some more pics
looks like a very good multifunctional screen, want one defo.
but which one 23" or 27" both have the same resolution. seeing as its primary use will be as a television and some people said tv picture is ok nothing special, surely its going to look much better on the smaller model?
elpedro, have you tried connecting it to the pc using hdmi cable? What was the effect? Does it run at lower resolution?
Thanks
I'm in the market for a 20"+, 16:9, 1080p monitor/TV. After reading this mini review I almost settled on buying this model but the fact that it can't handle HDMI from a PC has put me off.
I'm now looking at the Samsung SM2333HD, £245 on a competitor's site, looks like a good monitor but I'll be damned if I can find any professional reviews on it.
Hard to describe, it doesn't lower the resolution but the picture isn't as sharp. My old LG set, when you ran HDMI, you could chose between a PC and a Video setting. The PC setting made it pixel perfect sharp, the video setting is what this set (M227WD) looks like. I can't really explain it, but its not as good as the DVI connection for use as a PC monitor.
Maybe someone can better explain this than me who knows what I mean Failing that, I could take a photo with my dSLR which should be able to show the difference.
How are the vertical viewing angles mate? Do you know what type of panel it is? Looking at getting the 27" version...
Ive used my PC on this TV/Monitor via VGA and DVI and its brillaint.
why are you so hung up on using it via HDMI? whats the big deal ?
I'd be grateful if you could take those pictures
thanks elpedro i have ordered one of these 22" LG monitors & your mini review helped me make the final decission.
Ha awesome, what's even cooler is I'm guessing you found this review via google as that was your first post on this forum
thanks elpedro i have ordered one of these 22" LG monitors & your mini review helped me make the final decission.i currently have the 24" Dell s2409w (really nice image quality) but i need a monitor & tv all in one so i can watch tv & use my ps2,gamecube aswell as PC.
@moving tables nice pics is that 22" or 23" it looks nice & big.
