It has. Top left.
How do you know this? was it in the launch vid?
I havent seen it mentioned
It has. Top left.
ive got a feeling it hasnt got a notification led
i seen it in white which gives me hope its rgb. if its there even if its not rgb i still want this phone
it really is a cut (in appearance) above the rest imo
LG G3 battery life test reveals about 6 hours of on screen time with maximum brightness
http://www.phonearena.com/news/Firs...ery-life-tests-show-promising-results_id56590
One of the pictures in this article shows the LED lit up in blue, so I expect it is RGB:
http://www.engadget.com/2014/05/27/lgs-g3-is-official/
3GB is supposed to be on the 32GB so just get the 32GB?
If those screen on times are true and not just a video playing with no other accounts syncing, cell activity and so on, you know, actual smartphone stuff, then it should be a nice step up from other high end phones like the Note 3.
the guy tests streaming on-demand video through his carrier's LTE-A network, but keeps the phone in portrait mode, and often interrupts the test to see the battery percentage left. Still, he also tests the G3 endurance at the screen's full brightness, and clocks 7 hours and 47 minute of screen-on time out of the handset. The result is an hour and change higher than the previous test, as when you view the video in portrait mode, the adaptive frame rate tech likely kicked in for the static part of the image, thus helping the phone last longer than in the usual landscape mode that videos are watched in, and batteries tested.
I really hope the Nexus 6 is basically this, looks a great phone could be made even better by £100 off and stock android! Best flagship so far imo.
Wtf is Android silver? I'm so out of the loop.
