Lian Li O11D- Mini....(latest post with AIO Up top in ATX format)
27 Nov 2006
Coventry
Latest update is now early September according to replies on their Facebook post.
https://www.facebook.com/LianliGlobal/posts/1524635121024844.
Not sure if I should wait or not. If I have to drop something like £150 on an SFX PSU, that might make me change my mind too.
Currently swinging towards Corsair 280X instead, or maybe just put up with the larger 011D. Not that anything is in stock anyway!
12 May 2014
Nice find.
The youtubers who saw the case earlier in the year, all said it used a SFX PSU. I don't expect that to change.
12 Feb 2014
Somewhere Only We Know
Cant hardly wait for that case, ive got everything at the ready to go in it, just might need a thicker radiator to help deal with the heat as i'll only be able to get 1 in it.
It also requires an SFX PSU guys, doesnt take a full ATX PSU.
27 Nov 2006
Coventry
Took a gamble on a new mATX board, so that's paid off. Already got a 280mm rad, will look to pick up 2x360s.
Hopefully we can pre-order soon!
They didn't say anything about SFX during the latest video. Hopefully it will fit ATX.
8 Apr 2018
The South Bronx
I know he didnt mention it, but it was mentioned in all other videos, and have a look at the size of the other chamber when he's showing you around the case, its tiny.......as in thin, theres no way you're getting an ATX PSU in there
According to the spec on Lian Li there's going to be extra motherboard backplates for swapping adapting to your system built, I don't know if I'm reading it right.
Model O11 DYNAMIC SPACE GREY SPECIAL EDITION – Chrome Mirror Finish
DIMENSIONS (W) 272 x (H) 446 x (D) 445 mm
MOTHERBOARD E-ATX/ATX/M-ATX/Mini-ITX
PSU 2, (L)210mm~255mm (max)
COLOR Space grey
MATERIAL (Front) Tempered Glass + Aluminum (Side) Tempered Glass (Body) 1.0mm SECC
FAN SUPPORTR (Top) 120mm x 3/140mm x 2 (Optional) (Side) 120mm x 3 (Optional) (Bottom) 120mm x 3 (Optional)
RADIATOR SUPPORT 120 x 360mm/120 x 240mm/140 x 280mm
GPU LENGTH length ≤420mm, height ≤159mm
CPU HEIGHT ≤155mm
DRIVES 4 X 2.5” SSD + 2 X 3.5” HDD
EXPANSION SLOTS 8
IO PORTS USB3.0 x 2 USB3.1 Type-C x 1 HD Audio
DUST FILTERS (Top) x1, (Side) x 2, (Bottom) x 1
12 Feb 2014
COLOR Space grey
CPU HEIGHT ≤155mm
EXPANSION SLOTS 8
Wrong case, that's the O11 dynamic with the mirror finish, the mini is going to factor for different motherboard sizes by changing the back panel, but it's not going to make the space bigger for the PSU
27 Nov 2006
Coventry
Yep, as above. CES 2020 back in January showed these as needing an SFX PSU, unsure if that was SFX-L too. I think that will remain as Jamin surmised. But I remain hopeful there is enough space back there for ATX too. I'd much prefer SFX and not have issues with tall GPUs. Especially as this is for water cooling, some water blocks are tall with their inlets/outlets.
Hurry up and let me pre-order this already, Lian-li & OCUK!
