LianLi Lancool 215 / Liquid Freezer 280
1 Aug 2006
Hi All
Looking to see if anyone has tried fitting a liquid freezer 280 in to a lancool 215?
I currently have a fractal definer5 with liquid freezer (first one) 240 - and this is tight to point where a 280 would be too wide and hit my ram (that said, this does have fans both sides - but it appears that the freezer 2 wouldnt fit either).
According to the ocuk page - it seems that 280 rads are supported, im just slightly concerned about the depth?
Any feedback would be appriciated.
OP
1 Aug 2006
No takers? Looking at the written Gamers Nexus article (they dont mention it on the youtube vid) - seems to suggest there is a 60mm gap from top of case to top of motherboard (up from the 55mm that lianli mention on their site) - the Freezer 2 looks to be 63mm including fans - so gives an 3mm overlap on to the board.
Looks vaugely possible next to the ram slot on this b450 tomahawk but just very very tight, plus will need to overlap the top mosfet heatsink so again is dependent on their height.
