- 21 May 2003
Hi. I have just had one disk in my raid array fail, and on rebuilding, there are too many @unrecoverable medium errors" on the other disk to rebuild.
So straight away i connected it to linux and used ddrescue to copy everything to a new 500gb drive. The failed drive is just a windows ntfs drive, one big partition.
after dd rescue finished (8 hours), only 500kb of errors. But the new hard disk wouldn't mount in windows to run chkdsk. it said the filesystem was "raw".
I've used testdisk, and I can see the data is there. So it looks like all the bits are in place, apart from the actual ntfs file system.
In test disk, to see the files I need to first change the sector size to 512. but then when I try and write the new partition table, it says "write error" with no more info. Logs say:
I Changed the geometry to ntfs sector size so I can see the files:
Then click Analyse:
Then try and write this partition table (as that's the one where I can see the files)
interface_write()
When I try and run ntfsfix on the drive:
I cant't run chkdsk becuase windows wants a nice ntfs partition for that.
How can I create an ntfs partition on this drive manually?
Any help is appreciated.
Code:
Partition table type (auto): Intel
Disk /dev/sde - 500 GB / 465 GiB - ST500DM0 02-1BD142
Partition table type: Intel
Code:
New geometry
Disk /dev/sde - 500 GB / 465 GiB - CHS 60802 255 63 sector_size=512
Code:
Analyse Disk /dev/sde - 500 GB / 465 GiB - CHS 60802 255 63
Geometry from i386 MBR: head=255 sector=63
FAT16 at 0/1/1
check_FAT: Unusual number of reserved sectors 6 (FAT), should be 1.
Info: size boot_sector 305172, partition 305172
FAT1 : 6-154
FAT2 : 155-303
start_rootdir : 304
Data : 336-305167
sectors : 305172
cluster_size : 8
no_of_cluster : 38104 (2 - 38105)
fat_length 149 calculated 149
NTFS at 19/0/1
get_geometry_from_list_part_aux head=255 nbr=4
get_geometry_from_list_part_aux head=8 nbr=1
get_geometry_from_list_part_aux head=16 nbr=1
get_geometry_from_list_part_aux head=32 nbr=1
get_geometry_from_list_part_aux head=64 nbr=1
get_geometry_from_list_part_aux head=128 nbr=1
get_geometry_from_list_part_aux head=240 nbr=1
Current partition structure:
1 * FAT16 >32M 0 1 1 18 254 63 305172 [NO NAME]
2 P HPFS - NTFS 19 0 1 60665 254 63 974294055 [System]
search_part()
FAT16 at 0/1/1
FAT1 : 6-154
FAT2 : 155-303
start_rootdir : 304
Data : 336-305167
sectors : 305172
cluster_size : 8
FAT16 at 0/1/1
FAT16, blocksize=4096, 156 MB / 149 MiB
NTFS at 19/0/1
filesystem size 974294055
sectors_per_cluster 8
mft_lcn 786432
mftmirr_lcn 60893378
clusters_per_mft_record -10
clusters_per_index_record 1
NTFS, blocksize=4096, 498 GB / 464 GiB
Results
interface_write()
Code:
1 P FAT16 >32M 0 1 1 18 254 63 305172 [NO NAME]
2 * HPFS - NTFS 19 0 1 60665 254 63 974294055 [System]
write!
write_mbr_i386: starting...
write_all_log_i386: starting...
No extended partition
Partition: Write error
SIGINT detected! TestDisk has been killed.
Code:
ubuntu@ubuntu:/tmp$ ntfsfix /dev/sde2
Mounting volume... Failed to load $MFT : Input/output error
Failed to startup volume : Input/output error
FAILED
Attempting to correct errors... Failed to load $MFT : Input/output error
FAILED
Volume is corrupt. You should run chkdsk.
