Not a chance.Thorpy said:Sexy ones.
pogo said:What sort of pics do you want?
Raikiri said:Any pics pogo?
jrodga, who is it made by? The only 256mb DDR3 I have found is £67 although I have found one inno3d card that has been listed as DDR3 for £53 but is actually ddr2.
hotdog said:Hi,
Ive just bit the bullet and purchased two of these 7300 cards. Just to add my two cents worth, mine have black pcbs, no external power connector and the best bit (i hope) 256mb of samsung ddr3 ram!
Im waiting for OcUK to send the rest of my system but i hope to seriously push 7600gt speeds very soon...
Not bad (fingers crossed) for a very small outlay - i have also come from the land of 6600gt silent agp.
PS i have decided against going for Conroe, i believe it sounds G*Y - almost as bad as my sig
hotdog said:Also what zalman cooler are you using? Is it possible to fit the larger vf900 model onto the card and use them in sli configuration?
hotdog said:Forgot to say -
Do you have one of those Nvidia SLI bridge connectors? I didnt get one with my mobo (i know its not sli, but well!), any ideas where i can get them from? Ive had a quick look around OcUK but cant see them
Gibbo can you bring a generic sli bridge into stock ? Im sure you get performance benefits instead of using software switch etc
Please correct me if im wrong!
hotdog said:Im gettting really into this card now are you going to try and do the pencil volt mod?
I really feel the cooler needs changing, the fan itself isnt too bad considering its price point - but below that ! OMG naff naff & naff thats the heatsink, the gloop and bracketing. It really needs the zalman or similar.
I have had a quick search around and there are a few sites giving rave reviews however no end users seem to have taken the bait and given it ago!
Thanks for the reply jrodga2k5
