1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
maths help?!
Discussion in 'General Discussion' started by grudas, 9 Jun 2010.
  1. grudas
    Capodecina
    hey! can anyone help me out with Venn Diagrams? im lost.. basically my teacher said you need to fix it/redo it but did not explain what was wrong.. so this is what i've done so far.. the other part is logic gates which is a part of the whole thing and i might have made a mistake with one of them (AND/OR/NOT)
    http://vstanced.com/datas/users/untitled_1_1.zip
    can anyone who properly understands them check it and tell me if i done it right or not.. i don't want anyone to do it for me just some help would be appreciated.. i need to hand it in tomorrow and it has to be right :eek:
  2. Macky
    Can't you upload a pic instead? Would be much easier; for us. ;)
  3. grudas
    Capodecina
    sure!
    [​IMG]
    halp halp! :O :D
  4. touch
    Capodecina
    I would say:
    AND
    A-B 0,1,7
    OR
    A-B 0,1,2,3,4,6,7
    A-C 0,1,4,5,6,8,9
    B-C 0,1,2,3,5,8,9
    NOT
    A 2,3,5,8,9,10,11,12,13,14,15
    B 4,5,6,8,9,10,11,12,13,14,15
    c 2,3,4,6,7,10,11,12,13,14,15
    only differences i have from you are:
    AND A-B
    OR A-C
    OR B-C
  5. frying_pan_cat
    Hitman
    I can't see anything wrong with the diagram but in part C) shouldn't it be
    A AND B = 0, 1, 7
    A OR B = 0, 1, 2, 3, 4, 6, 7 (you missed the 2)
    A OR C = 0, 1, 4, 5, 6, 7, 8, 9 (you missed the 8)
    And I think the rest are right
    Might wat to wait for someone to confirm though
    EDIT: ^^ Touch I think there should be a 7 in A OR C
  6. whitecrook
    Sgarrista
    I don't get this. Can someone explain or point to reference.
  7. [FnG]magnolia
    Pancake
    Intentional comedy? :D
  8. grudas
    Capodecina
    AND
    A-B 0,1,7
    thats the problem with AND as the teacher explained if its in the middle where all the circles meet, it does not need to be showed in a-b(at the diagram) where i have the 7 and he said for me to remove it so i did the same in part C which is what confuses me now.. should i leave 0,1 or remove it?
    @frying_pan_cat - thanks for noting them(a or b - a or c)
    @touch - thanks, i might leave with 0,1 and you missed a 7 on a-c ;)
    got any more ideas about 0,1 on part C?
    thanks for helping out!
  9. frying_pan_cat
    Hitman
    A B and C are subsets of the numbers 0 to 15. The diagram basically has 3 circles to represent A B and C and where they overlap is where they share numbers ie. they all contain 0 and 1 so the space where they all overlap has 0 and 1 in. The next bit is logical AND, OR & NOT, so A AND B is the numbers in both A and B, etc.
  10. frying_pan_cat
    Hitman
    0, 1 should be left in in part C since A AND B are the numbers on both A and B and have nothing to do with C. I think what the teacher is saying is that in the diagram you can't put 0, 1 in the part where just A and B overlap as each number should appear just once in the entire diagram and as 0, 1 are in C too they must therefore be put in the triple overlap.
    I hope that makes sense
  11. grudas
    Capodecina
    it does! thanks a lot! :) finally i figured it out lol..
