1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
metal ring
Discussion in 'General Hardware' started by Willbo, 9 Jul 2006.
  1. Willbo
    Wise Guy
    just found a small metal ring about the size of a £2 coin. i'm sure i got it with my PSU, but whats it for? SOrry for sounding so dumb but :rolleyes: its sunday night
  2. squiffy
    Banned
    Possibly a RFI choke?
  3. Jokester
    Don
    It'll be a ferrite core for limiting EMI interference from the PSU propagating down the various cables into your PC.
    Jokester
  4. Willbo
    Wise Guy
    so to be dumb again......1) how do i fit it? the holes not that big.......2)what cables does it go around priority wise?
  5. semi-pro waster
    Man of Honour
    It has always been around all the front connector cables on any case that I have ever bought, how necessary it is I'm not sure but there isn't any harm in it.
  6. Jokester
    Don
    Normally it should be fitted at the bit where all the cables come out of the PSU, but if it's not already fitted then I'm not sure how you're going to get it on.
    Jokester
  7. cobxx
    Gangster
    IIRC it's around the front panel connectors, not entirely sure how, but it's used to reduce EMI interferance. It could have come off when replacing the connectors or something...but it's not essential.
  8. semi-pro waster
    Man of Honour
    We might be thinking of different things here but I'm envisaging the small 'doughnut' shaped bit of metal that goes over the front connector cables to the motherboard, I'm not sure about anything that goes over the PSU cables directly.
  9. Willbo
    Wise Guy
    yeah sounds about right, i think i remember seeing similar in old pc cases around the front connectors......do i just put the cables through the ring or in a special way?
  10. bitslice
    PermaBanned
    the cables are wrapped around it at least once,
    more turns = greater inductance = ~more RF rejection
    sara's mum uses ferrite cores
    sara's mum is really cool
