Evening all! I've got a bit of a problem with htaccess.. Code: Options +FollowSymLinks -Indexes RewriteEngine on RewriteCond %{REQUEST_FILENAME} !-d RewriteRule ^(.*)/$ /$1 [R=301,L] RewriteCond %{REQUEST_FILENAME} !-s RewriteCond %{REQUEST_FILENAME} !-d RewriteRule (.*) index.php If a user visits http://willesley.org/shop this works fine, as the file doesn't exist so mod_rewrite passes it to /index.php which looks it up in the cms. The same goes for http://willesley.org/shop?edit which passes 'edit' as a GET variable to /index.php. http://willesley.org/campsite/ is an empty directory (no index file). Visiting this redirects to /index.php (as it should) http://willesley.org/campsite/?edit doesn't work - it doesn't pass the GET variable to /index.php. Anyone got any ideas why this is?
Are you sure the variable isn't being passed? I've knocked up a quick test page using the htaccess you've provided and used the following as my index.php to check what's being passed in the GET array and it seems to work ok. PHP: <html> <body> // loop through each querystring variable in the $_GET array and echo out each one's variable name ($keyname) and $value. <?php foreach($_GET as $keyname => $value) { echo("$keyname --> $value.<br />\n"); } ?> </body> </html>
