1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
monitor w/ displayport doesnt work
Discussion in 'Graphics Cards' started by Heatproofsean, 19 Feb 2010.
  1. Heatproofsean
    I have 3x24" widescreen monitors and the one connected to the displayport is black and will flicker the onto the desktop every 10-30sec and then go back to being black.... I have the latest drivers as well so I dont know what is wrong :S
    can anyone shed some light?
  2. Heatproofsean
    im using a sapphire 5870 btw
  3. twist3d0n3
    Capodecina
    check the cable is in securely?
  4. Heatproofsean
    nope just double checked and everything is screwed in tightly :(
  5. Supertaff
    Wise Guy
    Two things to check.
    I have a similar problem at start up with mine monitor conneced to the diaply port. Gives a refresh rate out of synch error. If I unplug the display port cable and then plug it back in everything seems to work fine. Pain to do this everytime I start the PC though.
    Also check out this thread as this guy is having similar issues.
    http://forums.overclockers.co.uk/showthread.php?t=18114353
    Taff
