Monsoon MMRS Two Tube Reservoir help needed
21 Nov 2017
OP
21 Nov 2017
hmm to bad the cs did not tell me this, then I would just go with Ek bay res sulotion instead.
Cant one just exchange he back part so it will be compatible with the d5 pump, if so suggestion to where to find?
OP
21 Nov 2017
cant find a backplate for d5 pump....
so if I have understood this correclty. I will need to add this to the system.
MMRS Acryl tube 50mm
Tension roods for the 50mm tube
and MMRS END CAP WITH D5 PUMP MOUNT - BLACK
will that comple it with what I already have?
