1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Motherboard help :D
Discussion in 'Motherboards' started by Allnamestaken, 15 May 2010.
  1. Allnamestaken
    Mobster
    You guys have any idea if I could find a motherboard that supports the newer phenom II processors as well as ddr3 ram but can also be used with my phenon 9850 BE and the DDR2 1066 ram I have?
    Reason being I just want to get the motherboard for the moment and buy the Phenom II and ram in a month and half.
    I know My motherboard is able to run Phenom II processors though right now but dont want to get that first.
    Thanks.
  2. Orcvader
    Capodecina
    You won't be able to find a board that supports both DDR2 and DDR3 ram as they're physically different... Best buy the CPU first then upgrade the motherboard and ram together.
  3. Allnamestaken
    Mobster
    Got ya thanks mate. :)
