1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Motherboard Monitor
Discussion in 'Windows & Other Software' started by throdgrain, 9 Jul 2006.
  1. throdgrain
    Gangster
    Ive just installed this after a year or two of not using it.The thing is, the temperatures it reads seem very low. For example, the CPU temp this second as the PC is more or less idling reads 29 deg. However if I check Asus probe it reads 37 deg.
    anyone know how I can clarify the situation?
    Cheers folks :)
  2. Nick Diablo
    Have you tried CPUCool? It gives the same readings as ASUS probe for me.
    The software you have may not be looking in the right place!
  3. semi-pro waster
    Man of Honour
    I'd trust PCProbe as it is the manufacturers own official program, it seems fairly accurate to me whenever I have used it. Either of the two temperatures that you have listed are well within acceptable limit though.
  4. throdgrain
    Gangster
    I like MBM better though because its displayed better in the taskbar.
    Im now trying cpucool though, and it seems fine, so thanks very much for that suggestion :)
