1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Motherboard problem
Discussion in 'Motherboards' started by Chappers, 17 Jan 2006.
  1. Chappers
    I have just built my new system but I have a problem, basically it doesn’t power up.
    I have the following components:
    Asrock Dual Socket 939-SATAii Motherboard
    Opteron 144 CPU
    2 x 512Mb Corsair value RAM
    Thermaltake XP-90 Heat Pipe + Standard 90mm fan
    X800 AGP graphics card
    FORTON Blue Power 500W Power supply
    I know the graphics card is not the problem as it works in another system I have.
    When I attach the main power cable to the motherboard and turn on the power all the fans power up but no boot.
    However, whenever I attach the 12V connector it is like the motherboard is short-circuiting.
    The motherboard is balanced on 6 headers only one of which I did not manage to screw in, but it is still under a hole. Should I try removing this header?
    Also, Could the 12V connector be a problem? I notice it goes in two ways but neither seem to work.
    Could it be that I have applied too much thermal paste to the CPU and heat sink and this is causing a short circuit?
    Finally, I thought it could be the reset switch connector wired wrongly?
    Has anyone else experienced this sort of problem?
    If you can offer any suggestions then I appreciate it.
    Thanks,
    Chappers
