Hi all. I’m currently running the following in a P182: Q6600 @3.2Ghz cooled with Tuniq Tower GA-P35C-DS3R 4Gb DDR800 8800GTX 300Gb Verlociraptor. Looking at keeping everything as is but changing to motherboard so it will fit. Needs to have the same OC'ing abilities. Also would you recommend going from the P182 to the P180 mini in general? Thinking of size of GPU, would the air flow be sufficent? Any advice would be great. Thanks
I would go with a Corsair H5O, and mount the rad on the back 120mm fan. Having said that, I see no reason why your air cooler wouldn't work fine. As for motherboard - try either the DFI Lanparty JR P45-T2RS or Asus Maximus II Gene.
