Just bought a brand new E8400 for £95.
Keep us up to date on the OC
Mobo is a GA-G31M-ES2L. Ram is 2x 2GB OCZ Reqper-X PC2-6400 5-4-4-15. FSB=444x9, cpu volts=1.375v, DDR2 volts=+0.2v, FSB volts=+0.2v. All elese on auto. PCI-E has to be set to Auto or else I cannot get above 390fsb.555BUK
Fancy writing the setings you are using to get it at 4ghz and what memory are you using? if i go above 3.8ghz i get problems
what voltages are you using, and for what?
Yep, getting clocking and let your GTX stretch it's legs
