1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Multiple 6 GPU Setup and load calculations help
Discussion in 'Crypto Currency & Mining' started by meredec, 17 Jan 2018.
  1. meredec
    Hi
    This is my first rig and I have done quite a bit of research.
    I intend to build a 6 GPU rig using RX570s and another using 1070s. And if I can perhaps a third one..
    This is the wiring plan
    [​IMG]
    The PSUs are EVGA 1300W (slave) and EVGA 1600W (main) fully modular platinum rated.
    Risers are 6 pin or MOLEX powered (no chain, only single molex)
    Wattage estimate for MOBO+CPU etc = 200W
    Wattage estimate per card/riser combo = 250W/ea
    Total Wattage at wall estimate per rig inc. 10% contingency = [200 + 6(250)] = 1870W
    Single socket MAX = 13A*230V = 2990W
    This means 1 rig per each socket max load would be <65%
    Now my questions:
    Assuming the ring system in the house is 32A so max W are 32A*230V = 7360W
    Am I safe plugging 3x 6GPU rigs for a MAX total of 5700W so a load of about 80%?
    Should I get smaller PSUs?
    Any recommendation?
    I am a newbie so please be kind :)
  2. 200sols
    Mobster
    My 1070tis only pull 130w each, a single 1200w PSU should easily power that rig. Use 8pin PCiE splitters and power the card + riser together from the same cable.
  3. Karateyid
    Mobster
    Just a standard y splitter?? 6pin to 6+2 pin x2?
  4. 200sols
    Mobster
    8pin to 6+2 pin x 2.
  5. Karateyid
    Mobster
    Ah ok. Cheers will grab some for my rig as wanted to power card n riser from same pci if posdible
  6. mattyg
    Sgarrista
    8x 580's pulling 830w odd at the wall
  7. meredec
    Thanks peeps
    Will of course run the numbers with the Watt meter
    But in theory, for the circuit in the home, it is safe to load overall at 80% max?
  8. 200sols
    Mobster
    Yes, I assume it is RCD protected. But be wary of anything else on the circuit that uses a lot of power. If your house has two rings, just split between them.
