- 23 Jun 2015
Deleted.
How long is piece of string?
Covid, new tech, supply, Jesus' second coming - anything and everything could effect prices over the coming 12 months.
Plus, you ideally spec a system a maximum of a month before buying to get an idea of the latest tech you can get for your money. I would redo your list in October/November next year - a year is a long time in computers, your list will change.
*Got to ask - why the relatively small 240mm H100i with that monolith of a case and when everything else is to the max/premium?
I would personally be looking at high end air and a smaller case/footprint (among other cost saving changes for no discernible performance drop off.) - but appreciate, to a degree, if you're after a certain aesthetic.What other liquid cooler would you recommend?
But with that large case and your budget i would be looking at a 360mm configuration - with more subtle RGB.
The very overpriced 360mm Kraken Z73 LCD - would be one example - or the cheaper Corsair equivalent (i don't recommend the Kraken as it's very expensive - but ties in with your spending/premium build.)
It's the Elite CapellixIs the Corsair equivalent the Platinum edition?
Asking the wrong guy i'm afraid - i would have to look that up like you. Suspect there's very little in it. I mentioned the 360mm AIO as its more in keeping with your build, budget and case size.Ah, thank you. Is this better than the Karken?
But, a 360mm AIO in a well proportioned qaulity case will have no issues cooling your CPU. I would be more interested in the quality and noise generated by the fans. For your budget, i would expect relative silence...
Always top end air - less point of failure, cheaper and arguably quieter.
Should make your decision for you - Corsair takes it (Kraken - style over substance - i.e. expensive even for an AIO):Let's see if someone can assist.
