1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Need help picking new cooler want 4ghz
Discussion in 'Overclocking & Cooling' started by CAPTAINBUMFLUFF, 15 Apr 2010.
  1. CAPTAINBUMFLUFF
    Hitman
    I have a i7 930 on a gigabyte x58a-UD5 motherboard with 6gb of crucial tracer 1600mhz. I have got it 24hours prime stable at 3.8ghz with the following
    Cpu voltage=1.2
    QPI=1.3
    CPUpll=1.8
    Ram voltage=1.64
    Loadline calibration level 2 enabled
    All this is cooled with a Noctua NH-U12P SE2 which on load temps go up to 71 degrees centigrade. But when I push for 4ghz I need 1.275 volts to keep it prime 95 stable but temps go upto 84 degrees which is too hot. Any ideas what I can do, do I need a new cooler, as you can see airflow is good. Thought this is supposed to be a good cooler with its premium price
    [​IMG]
    Both fans on cooler blowing air out of the case
    Thanks guys in advance
  2. setter
    Caporegime
    Id suggest the Thermalright ultra extreme, also the prolimatech megahelems and the Thermalright venomous x are highly reccomended.
  3. CAPTAINBUMFLUFF
    Hitman
    You know how much difference a venomous x would make can see one on mm atm, dont want to get cooler for sake of it wondering if something I set in bios is wrong Speedstep and C1E are turned off
  4. setter
    Caporegime
    Im currently using a TRUE black, (lapped) on an i7 920 @4ghz, (venomous x is a new version of the TRUE) 1.2750 vcore, load temps hit 71-69-68-67, 2 arctic cooling F12 300-1350 rpm pwm fans on the cooler, speedstep/c1e disabled. Your case airflow and ambient room temp will also affect temps.
    TRUE push/pull
    [​IMG]
  5. CAPTAINBUMFLUFF
    Hitman
    Looks good would my noctua fans cool as good as those if ambient temps are the same
  6. setter
    Caporegime
    The noctua's are probably a lot better than the arctic's that im using, pretty cheap fans that i picked up for a fiver each.
  7. strumpusplunket
    Mobster
    NH-D14, surely, if you want air rather than water? Most review sites have it 5 or so degrees below the Megahalems, Ultra and True at load. Expensive and massive, though...
  8. CAPTAINBUMFLUFF
    Hitman
    Even better than the corsair h50-1?
  9. strumpusplunket
    Mobster
  10. setter
    Caporegime
    The Noctua DH14 is a fantastic cooler, but due to its massive size it can severely block ram slots, of course this will depend on board space and ram used. Definitely a no no for me as im using ocz reaper ram, which has a very tall heatpipe assembly.
  11. Kill_Phil
    Wise Guy
    yeah only real improvements you will see is either from a noctua dh14, possibly a h50 with a push/pull set up or lastly a full out custom water cooled loop
  12. demonfatality
    Gangster
    ive the prolimatech megahelems dual fans. i7 920 @4ghz max core temp is 71 degrees thats on a hot day under prime 95 .i really like this cooler it has the best bolt through fittings ive seen. i have 2 Akasa AK-183-L2B Amber Ultra Quiet 120mm Fan in push pull i reckon if i stuck 2 apaches on i could shave another 3 degrees
  13. Helios1234
    Hi
    [​IMG]
    Tidying those cables may also help temps.
    My personal recommendation would be to get the VX and keep the two Noctua fans. It would end up cheaper than the NH-D14.
  14. jordan282
    Hitman
    megahalem baby ye
  15. tfganhao
    have you tried push/pull on those fans before deciding to buy another cooler? Thats what i've set my NH-D14 to do. (havent got temps, waiting on a component to finish my build).
    Also, what others said about the D-14...its just gigantic, i spent an afternoon to connect all the wiring to the MB in my fractal case coz the cooler eats tons of space.
  16. CAPTAINBUMFLUFF
    Hitman
    Dam looking at that graph my cooler is terrible
  17. setter
    Caporegime
    I once tried the nocua nh-u12 on a q6600 i had at 3.8ghz, no use whatsoever, very quickly went back to my TRUE.
  18. CAPTAINBUMFLUFF
    Hitman
    Was it that bad?
  19. Helios1234
    I had the Noctua NH-U12P originally as well and never realised that it was that bad compared to other coolers on the market.
  20. lazer46
    Hitman
    A Heatsink is only as good as the fan it uses.
