1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Need Help - Updated BIOS for DFI LP Ultra-D - now can't boot
Discussion in 'Motherboards' started by zepplin, 16 Jun 2006.
  1. zepplin
    Gangster
    Hello,
    I just updated my BIOS for the DFI Lanparty NF4 Ultra-D. I downloaded the 406 bios from DFI site and used Winflash to update. That appeared to go successfully and then i was asked to reboot the pc, however the PC will now not boot at all, the screen just remains blank with nothing coming up! What is the story here, am i screwed? I backed up the original bios but i cant even access that now. Any suggestions?
    Thanks
  2. nbkpsycho
    Perma Banned
    Tried reseting cmos ?
  3. zepplin
    Gangster
    yep, i've resetted the cmos and re-updated the bios...worked this time around, thanks
  4. squiffy
    Banned
    It's most likely dead, but see if DFI has a BIOS recovery method. ie Gigabyte Dual BIOS, Asus Crash free BIOS (don't know if latter is 100% safe after a bad crash, but Gigabytes is with second BIOS chip)
    email DFI.
