Need help with the NVIDIA Control Pannel
27 May 2010
Currently Im looking to get the best performance and at the same time graphics out of my system for gaming. I was wondering if anyone could give me some insight on the setting on the control pannel to help me do this
My system is:
BFG GTX 295
2.80 Ghz Proccessor
4GB RAM
Here are the settings that I currently have on:
Ambient Occlusion > Off
Anistropic Filtering > Application-Controlled
Antialiasing Gamma Correction > On
Antialiasing Mode > Application Controlled
Antialiasing Setting > Application Controlled
Antialiasing Transparency > off
Extension Limit > off
Maximum Pre render frames > 3
Multi-GPU Performance Mode > Nvidia recommended
Multi-display/mixed GPU Acceleration > Multiple display performance mode
Power Management Mode > Prefer maximum performance
Texture filtering Anistropic Sample > On
Texture Filtering negative LOD bias > Allow
Texture Filtering Qualilty > Qualilty
Texture Filtering Trilinear optimization > On
Threaded Optimazation > Auto
Triple Buffering > On
Verticle Sync > Use the 3D Application setting
Man of Honour
13 Oct 2006
I usually use:
Antialiasing Gamma Correction: Off (bigger performance hit, don't really notice the difference usually unless you study screenshots)
Antialiasing Transparency: Multisample (minor performance hit but looks much nicer)
Maximum Pre render frames: 1 (Doesn't make much odds but I find this works pretty well with most games and very minor increase in responsiveness - 3 is generally fine tho)
Multi-display/mixed GPU Acceleration: Single display performance mode
Other than that pretty much as you have them.
OP
27 May 2010
I usually use:
Thank you.
