1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
NEED URGENT HELP...
Discussion in 'General Discussion' started by .Kencs, 21 Mar 2011.
  1. .Kencs
    Mobster
    Right, in my back garden there is a foul smell, looking further down my garden there is a man-hole cover with water all around that stinks.
    Now, my wife's dad (we rent his house while he lives abroad) said that the pipe that drainage runs through is not connected to this house, the pipe just runs at the bottom of their garden.
    We spoke to the neighbour behind ours and he said theirs is blocked too, but they had their drainage people out (who he has insurance with) and he said the problem is our end, yet we have been told that our house does NOT connect to that pipe and out pipe runs through our front garden and that is fine as our man hole isn't backed up. Would these 2 pipes be linked?
    Where can I get a map of the drainage system in my area ASAP to prove him wrong? He is trying to say it is our problem.
    Any help would be greatly appreciated...
  2. Jedeye
    Gangster
    Your local water company should have drainage and sewage maps available, but they often come with a price attached. I think South West water charge around 50 notes for them, and that may include snail mail postage. Not really the urgent help you need I guess :(
  3. Danm54
    Wise Guy
    Do you have poo coming out your toilet?
  4. Fourstar
    Wise Guy
    Call up your water company and explain the situation. They will be able to pull up a map showing the layout and advise you of whose problem it is.
    Have quick read of this post of mine from last year will explains the jargon of drain/sewer types and who is responsible for fixing them:
    http://forums.overclockers.co.uk/showpost.php?p=17180950&postcount=47
    If you lift the manhole out front and water passes through it when you turn the tap on it is a virtual certainty none of your pipes go into his.
  5. Envoy
    Gangster
    Try the environmental health department, they can help sort this stuff out.
  6. finga
    Hitman
    if the pipe is running through your land but its not you that is connected to it, then the liable party is the next property attached to the drain, the local water board will come and look at it for you, they usually put a camera up there to find exactly where the blockage is, you can then notify the person who caused it and ask them to get it sorted, you may have trouble with that if they dont actually want to pay for it, I had this problem the other year with a neighbour who kept pouring fat down the drain.
    Local water board will tell you what you can do and will clear it for you, they did for me
  7. .Kencs
    Mobster
    Can anyone help? I need to find out if this pipe is ours...
    Running kitchen tap with red dye down the plug-hole = flows through the man-hole in the front garden.
    Running the bath / Flushing the toilet = Goes through the front man-hole
    There is nothing in my household which goes in my back garden...
    I will upload a photo shortly...
    Council wont touch it as it is on private land.
    Dyno-Rod wont touch it as its not ours and we aint willing to pay as its not our fault
    His bloke wont touch it as its our problem...
    Constantly hitting my head against a brick wall...
    I need these plans tonight...anyone?
  8. Windle
    Capodecina
    Depends on if the sewer in your back garden is "private" as water company are only reasonable for mains sewers. If it's a private connection sewer they won't help you much at all.
    Also although they can provide a copy of their GIS for the area they will probably charge and you won't get it immediately and it will likely only show mains sewers so see above re private/water company pipes.
    Only way you will get plans tonight is if you know somebody who works for your local water company and is sitting at one of their machines with GIS access. You could phone the helpline and ask if they can tell you if the pipe in the back garden is mains sewer or even on their system but they probably won't have access to GIS themselves.
    Ask your next door neighbour if you can chuck some dye down his toilet and see where it ends up.
  9. .Kencs
    Mobster
    [​IMG]
    This has got worse since the neighbours sewer bloke came to have a look, which I have had words about anyway...
  10. bushmins
    Mobster
    Cement it up. That'll learn em.
  11. TheBigCheese
    Mobster
    I would think that all you can do tonight is invite your neighbour round, show him you throwing dye and water down the various drains and loo and show him where its coming out.
    Then go round to his and do the same thing...obviously you need to keep on good terms with your neighbour while you do this...
  12. Fourstar
    Wise Guy
    Bit hard to make out the pic.
    Looks like your neighbour's contractor pulled the lid off the inspection chamber and left it off? Sewage is emerging unimpeded whenever your neighbour uses water?
    Unless you can get your neighbour to capitulate I'm not sure what to suggest other than getting onto the council and environmental health.
    If you get no joy from any avenues the keyboard warrior in me would say put the lid back on and seal round the edge with rapid setting cement.
  13. Fourstar
    Wise Guy
    This may help.
    This may also be of help. It is from Kingston council but yours is probably similar.
  14. J-FRO
    Mobster
    Think it costs £4 but you can enter the details of the address you're at here:
    http://www.landregistry.gov.uk/www/...9ZQnB3LzZfTEY1NDE4RzdVMU9TRjBJOElDODNVVjIwRzI!
    That will give you the title register of the property, and as those drains are not yours, it should say either under the Proprietorship Register or Charges register on the Title document who's drains they are.
    EDIT: Link was too long, at the top of the page it says "Find a Property" click there and enter the details.
  15. bitslice
    PermaBanned
    If your drains work OK, just wait. Eventually he'll have to sort it in order to flush his loo.
  16. Fourstar
    Wise Guy
    The trouble is his neighbour's drain crosses his land and is causing a turd volcano in his flower bed.
  17. Zid_
    Hitman
    what's the haps OP?
  18. .Kencs
    Mobster
    He is doing my head in now. My wife just rang saying he came round today and is still insisting it is our responsibility, He brought some plans round which show the drain going under our back garden, down the side of the house, then ours joins on to theirs by ANOTHER damn man hole at the front of our garden in the corner buried under loads of soil, we never knew we had, but surely wouldn't that means the water would back up to my front drainage if they are connected, and not just through the back which his is directly connected to?
    I'm going to go home tonight, pull up that drain cover, and check if there is a blockage. If there aint, Im dragging him down, if there is, then fair enuff I will get it looked into on my side but my drains in front garden would surely back up?
    In regards to the 'Fourstars' comment, the man-hole cover had 2 halves of a slab on the top we use to put a plant pot on, their guy has lifted this and left it like it, making it worst, but has no touched the man-hole cover...
  19. neil3k
    just give dynarod a ringq
  20. .Kencs
    Mobster
    They are coming out tomorrow, and no-doubt it will be expensive, but he is also going to write up a report to show it isnt our fault they are blocked, but I have to check the front drain to make sure i dont look an idiot :)
