1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
New fan help please (replace stock cpu fan)
Discussion in 'Overclocking & Cooling' started by drogon, 13 Mar 2010.
  1. drogon
    Gangster
    Hey,
    I've got my athlon ii unlocked as a phenom ii at 3.4Ghz (up from 2.9)
    The stock cooling seems to be doing the job for now but its idle at 42 and almost 60 at full load. I'd like to bring that down by about 5- 10 degrees and push it up to 3.6 Ghz hopefully.
    I need a custom fan for around £20
    Also will I need to clean the cpu before I install the new fan?
    Cheers
    Andy
  2. setter
    Caporegime
  3. Jotunkaiser
    Gangster
  4. drogon
    Gangster
    Thanks for the replies guys.
    I had the fan on my old x2 and it was great. Sold it with the old cpu. Will this be ok for am3?
    Cheers
  5. setter
    Caporegime
  6. drogon
    Gangster
    I think the 64 one you originally suggested does support am3 too as I've checked a few other sites. I'm inclined to get that one as it seems better than the freezer pro 7?
    Andy
