1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Newbie Asking For Help - H110+ Pro Rig Issue
Discussion in 'Team OcUK Distributed Computing Projects' started by Rumel, 7 Apr 2021 at 09:52.
  1. Rumel
    Hi All
    Newbie to the forums and to the world of crypto mining.
    Recently started building out my mining rig and have come across some issues and hoping somebody can help.
    Spec:
    Asrock H110+ Pro BTC MoBo
    Intel Celeron G3930 CPU
    Windows 10 Pro - unregistered
    2 x 4GB Corsair Value Select DDR4 Ram
    Samsung 850 SSD 256gb
    550w PSU - for MoBo and SSD only
    2 x HP Server PSU 1200w
    2 x Breakout Boards
    6 x ASUS 1080ti Strix GPU
    I've installed all GPU's one by one, and has been all good. Eventually it will house 8 x 1080ti and 2 x ASUS AMD RX5700xt.
    All the GPU's and risers (6 GPU and 6 risers) are equally distributed among the 2 x 1200 watt server PSU. Everything boots up fine, all the GPU's are all showing on device manager and even are able to benchmark/partially start mining on NiceHash.
    However after about 15 minutes of being on, it completely shuts down. Initially thought it was a power supply issue, so ensured there is nothing connected to the Mobo PSU and moved all GPU's and risers to the HP server PSU, however still no luck. The temperatures on the GPU and CPU barely reach about 50 degrees so it cant be a temp issue shut down.
    Any help would be great.
    Thank you
  2. MikeTimbers
    I think this is in the wrong forum. You should post this in the crypto forum
