Caporegime
- 18 Oct 2002
Yeah these cards aren't gonna be made for anything less than top-tier cooling, but I'm sure that mITX will be served well with the mid-range as normal
And what are all these rumors of ridiculous performance gains, the figures being throw about like 2.7X just seem too good to be true
The problem here is if the MCM AMD graphics card uses a pair of mainstream GPU chiplets,then at 400W~500W it doesn't look great for the mainstream. This is because mainstream graphics cards will get the worse binned GPU chiplets!
The big performance gains are coming from extra power to the cards rather than any particular tech advancementAnd what are all these rumors of ridiculous performance gains, the figures being throw about like 2.7X just seem too good to be true
Leaks say only the 7900xt is MCM with all other cards being monolithic. In that regard if the 7900xt is 450w, then the monolithic cards should be well under that tdp with just a single die.
MCM GPU is expensive to manufacture and eats a lot of power apparently - it wil be a beastly card, but at this point can only serve the ultra enthusiast market, will be priced accordingly as it's bleeding edge tech with a bleeding edge price
What has happened here? I thought the new generation of GPUs were supposed to be more efficient but it feels like power requirements are going up. 2 more generations and we will be up to 1kw GPUs at stock speed.
They'll cost £2000 and come bundled with a PSU
You won't have to run heaters in winter = lower electric bills
Probably an aircon unit as well, you'll need it in the summer the 3090's bad enough as it is and I'm not even joking mine is power limited to 85% at present or the room turns into a hothouse
How do you work that one out?! 500w is 500w whether it comes via the gfx card or the electric heater
