- 17 Aug 2020
LOL I follow along now =)Yeah, I meant without the “higher” part!
Yes i know but i dont want to move it as many times and will change the 420 to a Watercool Mo-Ra360. With setup i can run the rad and case fans with 500RPM and its silentNice set up.
External rad is cheating slightly
The only outstanding issue I have is being unable to control the Crucial Ballistix RGB. It's currently on its strobing colour changing pattern which is distracting. I've tried using RGB Fusion and Crucials own MOD software and neither can control the RGB. Crucial are allegedly working on a fix so hopefully I'll have that resolved soon and can then control the RGB better.
Yeah I tried that but I couldn't live with the amount of garbage it installs on your PC. It installs so much junk that you need to download another app to uninstall it all. Crucial have told me they think they have it resolved and are working to get an updated MOD app out.I had the same issue, Armoury Crate worked for me!
The Arctic P12s are known to have a motor hum noise around 900-1000rpm. Outside of those speeds, they are as silent as the Noctuas. Guess it depends how much you want to spend on fans.I had horrific vibration with the sickleflow fans even with orings so i bought some arctic p12's to replace them.
They are fairly quiet at high rpm but when spun down at idle they seem to make an annoying whiring kind of noise.
I Replaced them with some Noctua redux fans and wish I had just bought them in the first place. They are louder at the same rpm but there's zero vibration or motor noise from them unlike the others.
I also just remembered, I can't use the Arctic BioniX fans as they are 30mm thick. I would be able to get one fan in but not really much point.
Anyone know where I can find fan mounting clips for a slim fan on a Scythe cooler? Can only fit a slim fan on the Mugen 5 as a second fan in the NR200P but cannot find a fan clip to make it work.
Been fine for me. I just run them at minimum RPM at idle, and have a fast ramp to take me over the 900-1000 range.
Yeah, the Noctua A12x25 are better. But they're not 5x better. £100 for four of the Noctua fans is madness.
I agree with you, thats why i bought the redux fans at £12.50, the price is much easier to stomach.
I'm just cheap
