1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
NTL Cable - What download speed should 1Mb cable give me?
Discussion in 'Networks & Internet Connectivity' started by Minstadave, 2 Aug 2006.
  1. Minstadave
    Caporegime
    Just sorted my new NTL cable account out with a hugely expensive phonecall to tech support (they'd messed up on their end) and was wondering what kind of download speeds I should be seeing with 1Mb cable.
    Currently I'm getting OVER 1MB per second downloads which doesn't make much sense to me? :confused:
  2. tolien
    Caporegime
    You mean you're getting 8Mbps (ie 1 megabyte a second) out of a connection that's meant to be 1Mbps?
  3. Minstadave
    Caporegime
    Yes my connection is 1Mbps NTL cable, but downloads are topping 1 megabyte per second, which is why I'm confused, but certainly not complaining :D
  4. ste_bla
    Sgarrista
    over 1MB a sec means surely your on the 10mb plan?
  5. Minstadave
    Caporegime
    I only signed up for 1Mb, I'll see what my bill comes in as at the end of the month :D
    Edit:
    Just tried a few more downloads, all are above 1 megabyte per second:
    [​IMG]
  6. Richdog
    Caporegime
    I hate you. :eek:
    Sure you didn't sign up to the 10MB and kind of miss seeing the 0 on the end? :D
  7. Minstadave
    Caporegime
    I'm 100% sure, I had the GF watching to make sure I didn't tack on any extras :D
  8. Phemo
    Very strange. You should be getting 120KB/sec - it seems they've put you on 10mbit by accident.
    What cable modem do you have? I'm guessing it's an ntl 250. Log into the modem's interface by going to http://192.168.100.1 and using the default login and pass of root and root then go to Operation Configuration. I have the 10mbit service and my figures are:
    Maximum Downstream Data Rate : 10240000
    Maximum Upstream Data Rate : 512000
    If yours are the same then you're on 10mbit :) It's obviously going to report that seeing as you're getting those speeds but at least it'll confirm your modem has the 10mbit config file. Just hope they carry on billing you for 1mbit.
  9. Minstadave
    Caporegime
    [​IMG]
    Score :D
  10. KizZ
    You lucky sod :eek: :D
  11. Imy
    Mobster
    During uni, I came back home for the summer and got NTL cable installed for a few months.
    They never billed me for it. They never reclaimed their cable modem.
    Best of all....
    When I tried to get reconnected the following year they would not believe me when I said I already had NTL lines installed.
