Is that idle or load temp?
Smithfields idle hot due to massive current leakage, it was an early 90nm intel process chip. But their load temps are normally only 15-20 degrees hotter, so 60 idle, 80 underload is not that uncommon especially if using the stock heatsink.
Its not the end of the world if a smithfield is hot, as long as the motherboard is set up not to thermal throttle too soon (Some motherboards override intels standard throttle temperature points, and insert lower temperature throttle points which are more suited to earlier northwood processors).
