1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
overclocked my 5870 and made performance worse, reset back and now worse still. help
Discussion in 'Graphics Cards' started by Ernie101, 12 Mar 2010.
  1. Ernie101
    I overclocked my 5870 using MSI after burner, after overclocking abit and testing stability i decided to run 3D mark vantage.
    results:
    5870 stock GPU score 16k.
    5870 925 core GPU score 14k.
    So it reduced my score...
    So i was worried and set afterburner back to defaults.
    Now my GPU score is 13K. and powerplay isnt working at all even at defaults settings...
    What have i done. :(
    EDIT: powerplay isnt working but instead my core is jumping from 400 to 850 and back at random when in desktop.
    Also 3D mark seemed to be really jerky when i overclocked it and returned it to defaults. like stuttering randomly
  2. chiLLZ
    Gangster
    sounds like afterburner is still overclocking your card. try uninstalling it and go to overdrive in ccc and make sure its set at defaults.
  3. Ernie101
    Ok i disabled unofficialoverclocking in afterburner config and restarted comp and its fixed it. few!
    However why did it do this in the first place? seemingly caused bad stuttering when it was overclocked. temps are below 60 degrees.
    Any ideas?
  4. Ernie101
    Is it because it needs more voltage? Can anyone with a 5870 please post any overclocks they've done and the voltages required. thanks
  5. Martini1991
    Caporegime
    I've never liked the unofficial overclocking thing.
    If you want to overclock it propelly, do so with it flashed.
  6. L0rdMike
    Capodecina
    Instead of making a new thread I just tested my 5870 and got a GPU score of ....
    16898
    Is that a good/normal score for a 5870?
