hp7909 said:To monitor, Speedfan. Analyse maybe SiSoftware Sandra Lite 2007 & CPU-Z
Also, changed from SystemWorks to the excellent TuneUp Utilities 2006. Also consider investing in Diskeeper 10.
Other programs you should/must have installed (& run/update/etc regularly) are:
All freebies which can be found here
- CCleaner
- SpywareBlaster
- Windows Defender
- Lavasoft Ad-Aware
lol What I listed is the best in its classt31os said:{snip}Just not needed when you have an AV that monitors that to, plus a decent browser{snip}
And start with THIS!! Although I would say "clean" is really too good for it - nuke is more like it!Clean said:I only use norton system works occasionally.
hp7909 said:lol What I listed is the best in its class
Since moving from Norton software, I don't trust/like all-in-one type software
I know that man but it's still screwing you up: Systemdoctor.exe is resident whether you're using it or not, and you probably have recycle bin protection on as well. Uninstall and you'll see a difference, especially if you're also using Norton antivirus! For the rest, a nice good clean with Spybot S&D will sort you out!Clean said:You mistook what I meant by ONLY. I meant i only used that peice of software occasionally.
I still think that you need to have a spy-ware program like Lavasoft Ad-Aware & run it every 2-weeks. As good as your AV is, spyware infection is unavoidable IMO, i.e. some time or some how, you'll get stuff will get through because it doesn't seem different from other traffict31os said:I use NOD32, its currently rated as the one of, if not the top AV protection.
