1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
PCI-E 6-pin power cord question!
Discussion in 'Graphics Cards' started by titaniumx3, 4 Jun 2006.
  1. titaniumx3
    I'm having some PSU problems and was wondering, is it possible to damage the graphics card if the 6-pin PCI-E connector was attached to the card, but no power was being supplied through it?
    (The card in question is a radeon x1900xt)
  2. senorstealth
    PermaBanned
    Nope shouldn't damage the card, the lack of power just means that the card will clock slower
  3. titaniumx3
    The thing that worries me is that I saw blue spark/flame like things coming out from underneath the red heatsink strip (near the back end of the card). :eek:
    The GPU fan was still running, but obviously I turned the computer off as soon as I saw this.
  4. squiffy
    Banned
    You could fit PCI-E into the HD/optical drive outputs, and vice versa with the Enermax Liberty range of PSU's, the connectors are colour coded.
  5. titaniumx3
    BTW, do you think the Enermax Liberty 400W could run this system?:
    Athlon64 3500+ ([email protected])
    2x512mb DDR400 RAM
    Asus A8N-E Mobo
    Radeon X1900XT 512mb
    Creative Soundcard
    2x120gb hard disks in raid-0
    1x250gb hard disk
    1xDVD-RW
    2x120mm fans,2x80cm fans
    The 400W Enermax Liberty does seem to have some hefty 12v rails.
  6. danceMB
    Wise Guy
    IMO opinion you cant go wrong with Tagan PSU range. Yes, they might be a little pricey for what they are, but they are the most solid PSU's you can get and wont ever let you down
